SOLD: Tiny/Barebones ITX system
Status
Not open for further replies.
Machupo
Gravity Tester
I have an extra system I would like to unload as I am building a larger system with a discrete GPU.
Case: Generic tiny mITX case (see pic), no idea where the front USB ports went, but wouldn't fit with this psu anyway
Motherboard: Gigabyte B550i Aorus Pro AX
CPU: AMD Ryzen 5 5600G
Cooler: Noctua L9a-AM4 chromax.black
RAM: 64GB Corsair Vengeance DDR4 3600MHz
PSU: Mini-Box 160W-XT PicoPSU w/ your option of a 100W or 192W brick (the larger brick has a different 4-pin connector than what is shown, because I am using it with the smaller brick)
*No SSD/Storage (I am using it in the new build)
*Yes, there is a lid, I just took it off to take a picture of it running, lol.
$250 + shipping (will also take 0.0045 BTC)
Decades of heat under Machupo -- prefer paypal
SOLD
Doesn't look like it can fit a low-profile gpu in there does it?
If you can find one that is 35mm tall, you can give it a shot, but my guess is nope. Hence the 5600G (y)
Yeah, I considered that case (and similar ones) a few times myself, always passed because the PCI slot is borderline unusable, and if I was going that route there are more compact options with similar performance.
Status
