DarkDiamond
- Sep 21, 2011
This is my first (of hopefully many) posts here, so please be kind
I have Solaris Express 11 installed on a box providing iSCSI storage to two ESXi 5 hosts and I'm seeing what appears to me a significant performance issue. I have Napp-It installed on the SE11 box (great software for Solaris noobs like me - thanks Gea!) and got benchmark results > 200mbs for sequential reads and writes.
What I'm about to say isn't an exact measurement, but when I'm copying files from my desktop (Core i5 with two 500GB drives in RAID 0) to my virtualized file server on ESX1 or ESX2, I'm only seeing transfers around 30 MBs. If I copy a file from one drive to another within the VM itself (which eliminates my PC's connection as a bottleneck), I see less than half of that (around 10 MBs). I've tried swapping cables (CAT6), changing switches (I have both 1400-8G and 1800-8G HP switches), direct connection between machines but unfortunately still haven't seen decent performance. After configuring jumbo frames between the SE11 box and ESXi, I saw a slight improvement but nothing earth shattering. Jumbo frames are configured end to end (including switch). Side note: When copying the files, I'm monitoring CPU usage on the VMs and Host and I'm not seeing either of them even close to being pegged.
Shouldn't I see something a lot better given the performance of the storage pool local to the machine?
Any ideas/tips that I can use to boost performance? Any ideas if I've missed something on the network or iSCSI configuration either on Solaris or ESXi? I realize both of those questions are extremely broad, but hopefully you all can bear with my noobish questions
Here's the specs for my setup...
Storage Server
ESX1 and ESX2
Thanks
DarkDiamond
Storage Server
Motherboard: Supermicro X8SIF-O
CPU: Xeon X3440
RAM: 16GB ECC Registered
ISCSI NIC: Intel 82574L Chipset
OS: Solaris Express 11
Storage Pool: 8-1TB WD RE3 in a Raid 10 ConfigESX1 and ESX2
Motherboard: Biostar TH76B
CPU: Intel i3-2100T
Ram: 8GB DDR3
ISCSI NIC: Intel 82574L ChipsetThanks
DarkDiamond
