Hey guys,
I have a bit of an issue with Solaris 11 11/11 running on a...
Dell Poweredge 2950
2x Xeon 5160 (3.0GHz, Dual-Core)
16 GB RAM (4 x 4GB)
2x Integrated Broadcom Netxtreme II NICs
LSI SAS 9201-16e
Norco DS12-D
2x Intel 330 Series 120GB (mirrored boot)
6x Seagate 3TB ST3000DM001
Pool is configured as triple mirror (2 VDEVs, ashift=12). Only sharing protocol used is CIFS using the built-in kernel CIFS engine.
I would post a screenshot of my transfer graphs, but it appears you cannot attach images here. Basically, one second the box is on the roof (floods the gigabit link, 99% utilization). The very next second, it's at 2%. And then back up, and back down. All the way until the transfer is finished. I see about 25% CPU usage when it's on the roof, and CPU usage drops dramatically with the lulls. I suspect something else is interrupting it somehow, but I don't know how to use dtrace to find it.
I also noticed that reading from the pool is slower than from ARC for some reason. I've tried changing hashes etc, to no avail. Not using compression, dedup, or crypto for any throughput tests. rpool scrubs hit over 1GB/s (fletcher4), and dpool scrubs are hitting 600MB/s (sha256, proc capped here - disks can do upward of 900MB/s).
Any help would be greatly appreciated, and will provide more info upon request.
Dell Poweredge 2950
16 GB RAM (4 x 4GB)
LSI SAS 9201-16e
Norco DS12-D
