SOHW-1693S acting up.
Nazo
I've had the same DVD drive for a couple of years or so I'll admit. Now all of a sudden lately I've been having a problem where quite often when I put in a blank disc (particularly DVDRs I think) it will get stuck trying to read it or something. I can hear it as it spins up and makes an unpleasant sounding clicking noise, then continues to make that noise after every few seconds. EVENTUALLY I can get one to read if I catch it right between a burning program and all, but it can take a long time, irritates me to no end from having to deal with it, and more worringly, probably isn't good for the drive as that clicking can't possibly be a good thing... I should probably add here that I have autorun disabled as thoroughly as I possibly can (I've always hated it) so I don't think it should be the OS trying to read the disc any more than it must.
To make things worse, I just dug out a backup that can't even be as much as a year old and it started clicking and refusing to read the disc on that as well. I didn't see any obvious signs of discrot or anything and it's definitely not scratched as I only use it once in a blue moon anyway so I can't really see an explanation other than that the drive is messing up (not something I'd like to think about with my PSU already acting up when I shut off the system as well.) So far I haven't even gotten it to read the backup at all though at least it stopped clicking and the light finally went off after I tried quite a few times and waited quite a while.
There is one odd thing though. It may be just coincidence, but when I used IsoBuster to eject and reload the disc, it worked right off. It might have been blind luck or something, but it's a really weird coincidence as I've often seen it get past problems of a similar (but less serious) nature before. If it really were IsoBuster, that would mean that it is a software problem though... Weird that it can make the drive click like that if it is though (if I'm not mistaken, the clicking is caused by the laser assembly moving too far and stopping isn't it? I know it has a safety switch to normally stop it, but I hear a bunch of tiny clicks at once, not just one, so it worries me...)
