Software to combine and rotate .tiffs ?
HAQattaq
Not having much luck finding software that will rotate and merge multiple tiff files.
I need to be able to merge 10 or so individual scanned tiff files into 1 file. I have thousands of files that need to be sorted and merged.
Anyone know of some image software that can accomplish this?
Thanks
Do you have any basic experience with writing batch files or shell scripts?
You could probably whip something up in conjunction with imagemagick (free,cross-platform, and open source BTW).
Hmm, so you're saying you want them merged so it's a "tiff stack"? That is, one tiff file but you can cycle through the images kind of like frames in a single movie file? I think ImageJ might be good for that. Rotating and saving an image is trivial, of course.
Also, from a very brief search it seems that Irfanview can do the merging too. I'm banking you're probably already familiar with that program?
I'll look into imagemagick but would really like to use something already made to do what i need.
I haven't heard of ImageJ nor Irfanview. The stack feature in ImageJ sounds promising.
I must have been searching the wrong terms.
Thanks
Dude you should try Irfanview first, I think. It's an excellent image viewer (to replace the native windows viewer) and simple image editor software. It's usually one of the first things I install on my computer when doing a fresh install.
ImageJ is a much more powerful program designed for use by scientists pretty much. Btw I did not say ImageJ has a "stack feature"... I was just asking to verify that it's what you're talking about. I'm not sure what exactly the feature is called in ImageJ because I haven't done what you want to do myself; I'm just saying that I'm confident that it does have the capability to do it.
I can't believe I haven't come across Irfanview after all these years behind a PC!@!
It works and has a clean interface.
Thanks for the recommendation.
