Software solution to stream Live TV?
castun
I finally got my HTPC setup with a TV Tuner Card - The Ceton InfiniTV4 CableCard quad tuner. The next hurdle of course is being able to stream a live TV channel to other PCs and devices in the household. After much searching, it seems that many other people have run into the same hurdle, and it usually requires the addition of a hardware solution such as a SlingBox or Media Center Extenders. The Ceton extender itself costs $179. :(
I have a 360 I could put in the office and hook up to the 2nd monitor, but would prefer not to simply because the Wife wouldn't be able to do Kinect related stuff, and it still doesn't solve the issue for accessing the Live TV on our laptops or tablet.
I came across Media Portal, but to my dismay most CableCard tuners have no or very limited support. My Ceton for instance just doesn't work with it, period. Obviously, streaming an already recorded show is easy enough, but not really ideal.
I'm about to look at TVersity, which I've used the free version in the past for easily setting up a media streaming server, although I can't remember if the Pro version has the ability to do Live TV.
XBMC has a Media Portal plugin, but once again MP won't work on my tuner.
Asking you folks here for any help or input. I'm rather new to this HTPC stuff, and getting the wife to approve the purchase of the InfiniTV was likely only possible because we could save money by finally ditching the FioS DVR box. I'd hate to have to spend more $$ on more hardware.
I wanted to do basically the same thing so I got the HD Homerun Prime. That way I can set up whatever computers I want to access it. Unfortunately I don't see how you can do that with your current device other than with the use of extenders. Is it too late to return it and get something different? Either way, perhaps someone else here is more familiar with your particular unit and can find an acceptable solution for you. Maybe it does do what you need and someone will chime in with the answer.
Not too late to return it, no. I also originally looked at that HD Homerun Prime box, although decided spending a little extra $ to get an internal solution with an extra tuner would be worth it. Also noticed it needs an extra SDV tuning adapter to get all the channels, which I believe is not needed for the Ceton.
Small update, I did finally manage to solve my issue. I noticed there was no Network Tuners option in my Media Center, so I looked up their install instructions (what’s included in the box is only the quick install guide) and found out that the Network Tuner software is part of the install but not selected to install by default. After getting it installed on both the HTPC and my desktop, I was able to stream Live TV over the network. Also found out that the wife’s laptop is unable to support the Live TV streaming, unfortunately, though it can stream already recorded episodes. Can’t remember what graphics chip it has in it (fairly certain it’s not onboard Intel HD) but it’s not up to snuff.
