Carlosinfl
Loves the juice
- Sep 25, 2002
Guys - I am not sure what happened here but I think I have a problem with RAID (software) on my home machine. I am using it fine now however during boot up, I see something scroll by in red however it is un-readable at 100 mph so I decided to check out some md stats on the box to see if something happened to a disk or RAID array I setup and I can't understand what I am looking at so perhaps you guys can help.
To make things as clear as possible, I have 2 identical drives on the machine both via S-ATA. The drives are 2x Western Digital 160GB disks and I am pretty sure they are both good but I am not sure.
Here is what I see:
As you can see there is a section that should match up below as /dev/sdb3 however it shows remove...
Then there is my 2nd RAID
Is one of my disks bad? What should I do? Should I place an identical spare in place of /dev/sdb and see if it starts to rebuild?
Both drives feel warm to touch as they are both getting power and I visible in the BIOS so I know it sees the drives but perhaps it has failed sectors on the disk, I don't know...
Suggestions or comments from data above?
Here is what I see:
Code:
tunafish:/home/cwilliams/Desktop# mdadm --detail /dev/md0
/dev/md0:
Version : 00.90.03
Creation Time : Fri Jun 22 21:20:43 2007
Raid Level : raid1
Array Size : 19534976 (18.63 GiB 20.00 GB)
Used Dev Size : 19534976 (18.63 GiB 20.00 GB)
Raid Devices : 2
Total Devices : 1
Preferred Minor : 0
Persistence : Superblock is persistent
Update Time : Fri Jul 13 15:03:20 2007
State : clean, degraded
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
UUID : 93f4ddb3:70d5783e:f47a10c4:9fe19ef3
Events : 0.6582
Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
1 0 0 1 removed
Code:
tunafish:/home/cwilliams/Desktop# mdadm --detail /dev/md1
/dev/md1:
Version : 00.90.03
Creation Time : Fri Jun 22 21:20:49 2007
Raid Level : raid1
Array Size : 135275264 (129.01 GiB 138.52 GB)
Used Dev Size : 135275264 (129.01 GiB 138.52 GB)
Raid Devices : 2
Total Devices : 1
Preferred Minor : 1
Update Time : Fri Jul 13 15:08:02 2007
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
UUID : c627213e:cbaed46d:6510c67a:3cf96311
Events : 0.4564
0 8 4 0 active sync /dev/sda4
1 0 0 1 removed
Code:
tunafish:/home/cwilliams/Desktop# cat /proc/mdstat
Personalities : [raid1]
md1 : active raid1 sda4[0]
135275264 blocks [2/1] [U_]
md0 : active raid1 sda3[0]
19534976 blocks [2/1] [U_]
unused devices: <none>
