I'm setting up a small file server and want to get a basic raid 1 setup going. In the past I've always used hardware raid, never software raid before. I'm not sure what features will still exist with the software setup. In the current setup I have going, I would like to pursue software raid instead of hardware for a couple reasons. One reason is it is a small form factor build without a lot of airflow and all my hardware raid controllers always put off a ton of heat. Given the fact that the system right now runs very cool, I'd like to keep it that way. I guess my main question is that what happens when one drive fails in the software raid 1 in ubuntu?
Will everything still work and be accessible because of the mirror? Is the failed drive immediately recognized as failed? What is involved in replacing the failed drive? Can I just physically replace it and will the system rebuild the mirror on the new drive?
It seems pretty easy to find documentation on how to setup raid in ubuntu, less easy to find documentation on how it actually works. Thanks for your help.
