software overclockers
[Neural Interface]
I want to O/C an old mobo (Gigabyte 6MMW7 + CELY 700)
It cant be done in bios even after using the latest available and the manual I downloaded of Gigabytes site shows jumpers where ther arnt any.
So the only thing I can think of is software overclockers, I just wanna know of the programs that can overclock in Windows
thanx N.I
There is a program called clockgen, it does what you are takling about but you need a special version for each board.
http://www.cpuid.com/clockgen.php#support
only one is a p3 motherboard and its MSI so it looks like you are out of luck.
do a search for SoftFSB written by H'oda. It was a program that if your mb wasn't listed, you could select the clock generator it used and go that way.
not sure if it supports yours or not but it's worth a shot.
