mosin said:For DVDs you own that you want to make backups of?
just as simple for burningBut to simply have a complete DVD backup on your HD that doesn't matter.
Either way you can start ripping by pressing the large DVD button
Ice Czar said:considering Im to compare freeware with paidware Ive never used?
for the price of that ap + $20 you can get her another DVDRW
DVDDecrypter is pretty simple, just creates a decrypted ISO of the DVD
http://www.doom9.org/index.html?/guides.htm > ISO mode
Id recommend you going through it a few times with her, setting up any folders for the ISO
and write a cheat sheet text file for the desktop in case she needs to refer to it
then install Daemons Tools to mount the Image and watch it on the computer
DVDdecrypter has never failed me, and you cant beat the price
well for some reason dvd shrink will not burn my compilations.OldPueblo said:I just moved from DVDXCopy to DVDShrink. Was so easy to rip Shrek 1 & 2 to the harddrive and then turn around and combine them on to one DVD (minus spanish/french audio for better compression) for the long van rides.Quality was excellent still as well! Highly recommended. Why would I also want to add DVD Decrypter into the mix? What does it make easier when used in conjuction with Shrink (never used Decrypter)?
satriani5902 said:Can you burn with DVD Decrypter? I don't see an option there. thanks.
.............................................................................................ISO mode
There's actually 2 ISO modes, one for writing and one for reading
In order to access the ISO writing mode press W.
First click on the Windows Explorer like button in the left part of the GUI to select the image file to be burned. On the right side DVD Decrypter will indicate some info about the disc that's currently in the burner. If the disc is not empty the button to burn (once again a DVD button) will not be active.
If your drive supports BURN-Proof you should check this option, if you want to test-burn also check Test Mode. In that mode the burning process is only simulated and no data will be written to the disc.
Finally we have the Write Speed setting. Leaving it at max will burn the image as fast as your burner and media allows. If you rather like to burn slower, you can also select a lower burning speed than your drive / media combo is capable of. Note that selecting a speed that is higher than your drive / media allows will result in the disc being burned as fast as both drive and media can handle.
Once you've set everything up press the DVD button to start burning.
