octoberasian
- Oct 13, 2007
I know there are software such as RivaTuner and ATI Tray Tools, but trying to get them to run in Windows 7 x64 means the drivers they use will not load.
Using software such as Driver Signing Enforcement puts Windows 7 x64 into Test Mode.
I go through video card reviews such as the ones on Guru3D or here on [H], and others that use such software, do they go through this hassle as well?
I've had similar problem in Vista x64 as well. This is just ridiculous trying to get these to run, and I really don't want to resort to buying some $55 Zalman fan to keep my HD3870 cool.
No thank you.
Pressing F8 and Disable driver signing software at every boot up.
Too tedious, no thank you.
Editing boot up options with the following:
Code:
bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
Works, but puts Windows 7 x64 into Test Mode.
Is there a fan controller for Windows 7 x64 that will allow it to run without issue or doesn't having to go through loops in Windows 7 x64?
