We deploy lots of apps through active directory where I work via computer GPO. I'm having a devil of a time with adobe acrobat. It had been working before, but now when I try to install I get error:
Product: Adobe Acrobat 9 Standard -- Error 1316.A network error occurred while attempting to read from the file \\{Servername}\{ShareName}\Adobe932Stan_New\DianaAdobe\Acrobat932\program files\Adobe\Acrobat 9.0\Acrobat\plug_ins\HTML2PDF.api
File exists there, no worries. Domain Computers has full access to the share and to the subdirs. So does system and Everyone (at least for testing) I reboot, says it's installing. Fails. Login. Try to ping the server this stuff is sitting on(fileserver that's accessed regularly by all) and can't ping by name OR IP. After ipconfig /release /renew /flushdns and /registerdns I can ping. I can access other resources on other servers fine, just not this one.
Tried rebuilding the MST file, etc.
Friggin weird. No subnet changes or anything like that. No bad routes on the fileserver.
I'm confused
2003 native domain, full cisco env, windows xp/7 mix, sym av
I'm confused
