Softmodded HDD upgrade question
Cold Dark Shadow
Just stuck a 300GB into my softmodded xbox
Evo dash says on F there 126GB and 4.5 something on E
If i go into the Evo setup it says 278something on F
does that mean i do have the extra space on F its just not regging or do i need to do something to expand the space to use all that i can
I'm not sure, but some bioses can only detect 137gb so you may want to look into that limitation and if it exists on an XBox.
The other half is on the G drive its just not showing it on the Evox screen but its there in HDLoader :)
it did i added the G drive in the unleashed set up menu so now its got the Partition 1 Partition 6 and 7 :)
I think that worked lol but who knows :p
