soft mounts
thenness
Does anyone know if the intake fans in an Antec 900 can be "soft mounted" ? I was thinking of using these http://www.ncix.com/products/index.php?sku=9623 but i don't know if -
1: is it possible at all
2: would it provide any benefit, as the front grills look like they clip onto the fans (from the antec mechanical drawing)
Or does anyone have a better solution?
-thanks!
