TwiceSliced
- May 1, 2002
Can anyone recommend a readily-available Socket423-compatible HSF? I have an old PCChips board that I'd like to use, but one of the brackets for the clips for the HSF has snapped. There are two plastic pieces that mount onto the motherboard; the heatsink is then secured to them with two metal clips. One of the plastic pieces is the part that has broken.
