Socket-Tab Hold-Down Fine For DangerDen TDX?
V0ltage
why would you get a TDX block designed for extreme cooling but an absolute piece of crap motherboard thats going to allow little if any OCing?
/edit: that goes for both of them.
my answer: get another board and if it has holes, get a TDX with mounting holes. if it doesnt, get the one with the SHDT. they both work just as well.
well it seems that he is looking at mATX boards so he doesnt have alot of options when it come to one the overclocks well... the only one i seem to have found is the Biostar M7NCG it has full range of OC options... and its a decent little board.. i recently bought it for my new mATX water cooled system.. and i am almost positive that the TDX will have no problems on that board there should be lots of room for it....
