Socket T Questions
tree_
What is a good stable motherbaord for a Socket T 2.8 Gig? I don't really want to OC, use PCIe, or DDRII ram. Also, what is a good heatsink/fan combo to put on it to keep it cool? Thanks
That lan party would be perfec but is a bit high in price. Are there others like that but closer to the 100$ area and also I need ore suggestions for a socket T hs/f. Thanks
Now I need a decent heatsink/fan combo. I'm not sure what will fit a socket T since I don't see an actual socket T to select in the cooling section on the egg..
Also, where can I get the 24pin adapter on newegg? I don't see it on there... Or do I need something better than my offbrand 350W psu?
You don't need an adapter to use a 20 pin connector. Just make sure you plug it in to the leftmost end of the 24 pin connector (viewed from the hold down clamp side) Note that it WON'T engage the hold down clamp.
