The Supermicro H8DME-2 (dual Socket F) I have has two-hole cooler mounts, and as far as I can tell the Hyper 212+ only works with 4-hole mounts.
Is there anywhere where I can get a 2-hole mounting kit for the Hyper 212+? If not, can anyone direct me to a good cooler than works with two-hole AMD sockets.
AFAIK Sockets F and 939 have the same mounting holes, so a 939-compatible cooler would work; however, I don't know any off the top of my head that come with a two-hole backplate.
