Vlad335
- Apr 21, 2001
I just got my Asus A8V that I am going to use in my WC setup. It has a steel backplate under the socket to hold the plastic retention dodad in place. I have noticed in alot of reviews this is removed prior to putting the bolts for the waterblock thru the motherboard.
I don't understand. Wouldn't it be better to have this in place for added stability?
I didnt start mounting the block yet so maybe I am missing something. My block will use 2 bolt assemblies to mount my A64 3500+ S939. It has 2 screw holes holding the plate and plastic thingy together.
Let me know your experiences because I have none.
thanks
thanks
