fore1337
- Sep 28, 2004
Let's Abuse this little Sempron by OCing.
I picked up a $40 bundle for a first PC for a 12 year old for x-mas.
PC Chips M811LU(v3.1) mobo.
BIOS Phoenix
Sempron 1.6Ghz CPU
266 FutureMarks with an FX-5200 256mb, just crap! I'm trying to get him an R9600xt.
Memory: I will probably throw Corsair 512mb PC3200 Value in there, or something cheaper if I can justify it.
In the BIOS, my OC options are to tweak the FSB up to 165mhz
Stock: 133FSB x 12 => 1600, 32C
Ive been running stable with these settings.
Stable @: 160 FSB x 12 => 1920, 40C
The bios maximum FSB setting is 165mhz.
I tried doing a wire Vcore mod trick to go from 1.60 to 1.80 Vcore but the mod got me from 1.60V to 1.66V
Even if I successfully Vmod the chip to 1.8V the delta between 1920 and 1980mhz is negligible.
Is there any way I can change the multiplier from 12x to 13x or 14x ?
Given I do a successful Vcore mod from 1.6 to 1.8v and use proper cooling.
Cooling:
Stock HSK for AthlonXP 2400+ chip and 60mm Intel Fan (loud as hell)
I have a nice bootleg Zalaman Heatsink look-alike AL-CU HSK which will fit the socket 462.
CPU Database has an average OC for this chip @ around 2238 Mhz
I kinda missed out on the socket 462 or Socket-A thing. (went from Slot-A 750Mhz to Socket 478 P42.8C)
Mobo Random Specs:
KT266A/8235 chipset
BIOS AMI 2Mb Flash EEPROM, Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI, Full support for ACPI revision 1.0
Specs page from PCChips
BIOS Phoenix
Sempron 1.6Ghz CPU
Cooling:
Mobo Random Specs:
KT266A/8235 chipset
