schonsnow said:I know im slow to update, but im thinking of buying a mobile xp-m 2800. for cheap off ebay. do you think i would see improvements over my xp-m 2400?
I too would echo the remarks not to spend $$ on another socket A cpu which basically won't improve your existing performance. As you see I have the same model and OC'd quite a bit further. Our cpus are noted for their ability to run 2.5Ghz+ consistently. I'd be quite surprised if you couldn't extract another 100-200Mhz from that cpu.schonsnow said:I know im slow to update, but im thinking of buying a mobile xp-m 2800. for cheap off ebay. do you think i would see improvements over my xp-m 2400?
Actually if he's going to upgrade his socket he might as well go for a 939 set-up as the recent price cuts have made those super reaonable as well. I mean the 3500+ is $89.50 and the 3700+ $105. Shoot even a dual core x2 3800+ is fairly priced at around $150Roberty said:If you already have a socket a XP-2400 mobile then I wouldn't do it. Those will do 3200+ speeds on just about any POS motherboard (except maybe some Via chipset boards) and every one I ever saw will do 2.4ghz on a decent motherboard. If you have PC3200 memory then just put it 200x12 and it will probably run it stable at stock (desktop) voltage. If you get the itch to upgrade any at all, just get one of those $99 Newegg motherboard/cpu combo's. http://www.newegg.com/Product/Product.asp?Item=N82E16819103010
I just built one for a friend and have another ordered for a upgrade for my dad's system. Best "Bang for the $$" going right now, if you ask me. As much as I loved my old XP-2400m system, it just doesn't make much sense to bother messing with one anymore with Athlon 64 prices so cheap. The performance difference between your current socket A system @ 2.4ghz and the $99 2.4ghz Athlon 64 system in the Newegg link above is night and day.
Before the recent AMD price fallout I was thinking the same thing. Save my $$ for a serious upgrade in 07. DX10 Video Card, Quad Core cpu, the works. But now with prices where they're at it is hard to resist the upgrade urge.n3g471v3 d3c1b3l said:personally...I'm still running a socket A... (see specs below.) It was a budget system that I built... and still performs ok. If I was... well I'm about to build a budget system for a friend of mine, and I was going to go for a socket 939.. You can get them so cheep now. I'm waiting for feb-march 07 to build anything spanking new
