Socket A Motherbard Reccomendation
Chu
Hello all. I am currently looking for a SocketA board. The goal here is price/proformance ratio, not necessarly the best board out there. I am planning to purchase a mobile XP since they overclock like mad, and I have some really nice memory already, so now I just need the motherboard. Two things though . . .
(1) I have *ZERO* intentions of running it in dual channel. Memory is just too expensive right now to spring the extra for the second chip, and my next upgrade will be sometime in september, and prices will probably be a bit cheaper by then.
(2) I have *ZERO* need for anything onboard. I have a really nice server ethernet card that offloads work from the CPU, and my terratec sound card is probably better then anything onboard.
(3) As noted above, I do plan on overclocking the board so I really need to be able to control the memory/fsb ratio.
(4) I *NEED* Raid0. I do a ton of encoding and the extra speed is a godsend on my working drives.
Given these two things, what board should I be looking for? Since I don't need dual channel I don't even really need an nForce400. The one board I have been eyeing is the Shuttle AN35N-Ultra since I know it is rock solid and I've heard it is a decent (but not top tier) overclocker, and it is to be had around $60, but I would like some more input.
Thanks in advance,
-Chu
AN35N Ultra owner for 10 monthes now
No problems, fast and stable.
OCs to 220-230FSB stock, 240-250FSB possible modded.
Likes Buffalo\Winbond, Corsair, Mushkin, OCZ, & Crucial RAM, others can cause problems.
Regards, Szandor
Does your RAID 0 need to be IDE or SATA? Reason I'm asking is because the only company I can think of with a board that would overclock anywhere close to what you want is Gigabyte's nForce 2 boards.
nForce 2 is the way to go for overclocking. Yes, there is the dual-channel memory thing, but you're missing at most a 3% performance drop---which you really won't miss any way with overclocking like mad. Also people seem to find running DC lowers their OC potential.
Most boards you'd be interested in these days come with a NIC and on-board sound...though the on-board stuff tends to be total crap anyway (nForce MCP-T and VIA's ENVY are the exceptions).
--Abit NF7 Rev 2.0
--Asus A7N8X/A7N8X-E
--Epox 8RDA/8RDA3
--DFI LANParty/Infinity NF2 Ultra
--Abit NF7 Rev 2.0
--Epox 8RDA/8RDA3
PATA Raid0 setup. Also, just from scanning prices it looks like I will end up with a nForce2, thanks for the suggestions. I was really hoping to get away with spending no more then $70, but I will take a look at those suggestions.
Regards, Szandor
Yikes, what sort of problems?
Some of the Kingston and Geil sticks don't like to cooperate but I've seen the same problems with other nForce2 boards.
It doesn't like to initially boot over 200FSB with CAS2 LL sticks, for some it works for others it takes some tweaking. Some sticks require more than the 2.7 VDimm limit that the BIOS offers to run stabily at high FSBs. I run my Buffalo\Winbond PC3200 @220FSB\440DDR on Auto VDimm with no problems, I have friends with Mushkin Black and Corsair XMS that can run 230FSB with no issues.
Sweet little budget board but its a bit picky about RAM
Regards, Szandor
I can't believe how much raid0 adds to the price of a board. I am tempted to just say screw hw raid0 and let windows handle it, since it will pretty much be the only thing sucking up pci bandwith when I am using it, but that would require an additional IDE card, which would mean I would then need 6 slots (3x IDE cards, TV-IN, Audio, 2nd LAN). Any good boards in the shuttle's price range that have 6 PCI slots instead of 5?
-Chu
P.S., I have so many IDE cards because I like keeping 1 drive per channel, and the cpu/pci hit makes it worth it considering how often I have to move gigs of files around.
