Socket A Measurements + Mounting Holes
Zoio
Im going to try to build my own custom water block and i would like to know if anyone can provide me the Socket A (462) measurements and Socket mounting holes, for mouting the water block.
http://forums.procooling.com/vbb/showthread.php?t=8412
Ripped from procooling's forum. If you want design tips and feedback, you'll probably want to check out the procooling.com's forums... Lots of experienced members there, and they have their own water block construction folder (which is useful, considering the [H] does not have one). Good luck!
The drawings are pretty darn accurate, btw, i used them to make mine!
