Socket A decision help
Wolf-R1
To start off with I purchased an MSI K7N Delta2 Platinum board to replace a burned up NF7-M mobo in my g/f's computer. The MSI board was crap and wouldn't install WinXP. Got a replacement yesterday. Replacement shows the same problems that this one did except that it will manage to get past the "Starting Windows" part at the beginning of an install but hangs on choosing a partition.
The entire escapade can be read here: http://forum.msi.com.tw/thread.php?threadid=63796&hilight=woes&hilightuser=52861
Anyway...since the second board doesn't work I'm done with MSI on this project. I am contemplating either an Abit or Asus board for this and am leaning toward Abit's AN7 or NF7-Sv2. I already tried the NF7-S2G board but since it doesn't support multiplier locks the mobile AXP won't work with that board.
So what say you all? What board is a good board to go with? Looking to maximize the FSB useage and at least get the 400mhz worth of work out of the DDR400 that I will be putting into this board.
Thanks in advance. :)
Well this is a first...no on has any suggestions? :(
Anyone know if there are issues with the NF2 400 Ultra and AXP mobile chips? Should I just go with the NF2 400 then?
if you had the same problem with 2 boards and had one board burn up.
It could be something that isn't motherboard relates, i.e. bad PSU.
Also check your ram to make sure it's ok.Because 3 bad boards in one computer is definately not normal.
