To put it simply, the DFI nF3 250Gb is the best overclocking Athlon 64 board that we have ever tested. The range of options in every area is superb, and no one will feel that they are left short with this DFI board. For best performance, you should use one DIMM, but performance with 2 DIMMs is also impressive, as the DFI is as good or better with 2 dimms than the best of the Athlon 64 boards that we have tested. If you plan to buy a Socket 754 Athlon 64 and overclock it, this is the board to buy.
The above quote is from anandtech. They have tested the board and recomends it (also for non-Over Clockers).
It is all it has been made up to and then some obviously. I just cant wait for the 939 part hopefully that will arrive about the same time I return home to my Vapo
*Gratz* DFI!!
