socket 754 / dual channel ram
lodingi
are there any socket 754 mobo's that support dual channel memory? thanks.
Somebody correct me if I'm wrong (been awhile since I touched a s754), but I think all 754 motherboards are single channel...
although the 754 doesn't support dual channel, it will run dual channel tested ram ram no problem,
ram is ram, for the most part...
baldy
None of the S754 boards support dual channel mode because the memory controller of the procesor doesn't support dual channel mode, hence the creation of S939.
there is no such thing as dual channel ram.
memory controllers have dual channels. 939 parts have this.
754 parts have a single channel controller.
Right on.
Socket 939 operates with a 128 Bit memory bus. 64+64.
Socket 754 operates a 64 Bit memory Bus.
no S754 boards support dual channel, because with the K8, the memory controller is integrated on the CPU, and S754 chips have a single channel memory controller.
