Socket 1150 HSF deals?
Any of the 1155 mount HSF will work on the 1150 mounts. But I'm sure you know this. So basically any fan and heat sink will work that is out. But once you start overclocking then you will need a better one. After 4.5GHz they start to get a little toasty.Just depends on your needs and if you need to match a color scheme. Most seem to be happy with the H80i-H100i aio loops.
I know this doesn't really help you looking for a deal on one though. Sorry I couldn't be of more help to you.
