Which Volcano do you have? I was using a V-11+ on my AN35N Ultra but it was a real tight fit. I recently picked up the V-12 Extreme which fits much better, more room between socket and NB and caps. Runs excellent, flipped the fan over and dropped temps 2C and noise at full throttle by a lot, at 2100rpm its nearly silent. Last I knew www.ajump.com had much better price than NewEgg.
Psycho,
Sorry to hear of your dissapointment, Personally on my gigabyte 7n400 pro, im using the coolermaster hhc-001 heat pipe, fits without and modifications or touching anything.
Some with the giga boards have taken a dremmel to the offending parts of the hs and created clearance
You might want to have a look around Amdmb Gigabyte Forum seems there are several threads about what coolers others are using.
Gotta link to a picture of your board, I can probably tell you if the V-12 would fit. I found with my V-11+ that taking the fan off made it easier to squeak it by one of the caps to install it, I also removed the fan I added to the NB and replaced it once the V-11+ was in place.
