so what do you consider high resolution gaming?
Discussion in 'Video Cards' started by haadij404, Sep 11, 2008.
  1. JimmiG
    JimmiG 2[H]4U
    2,429
    Apr 3, 2008
    Well there's a difference between "High Definition", a term used mostly to describe consoles and TVs, and "High Resolution", used mostly to describe video cards and computer monitors. With a computer monitor, you're (usually) sitting very close to the screen, where as movies and console games are enjoyed from a couch, bed etc. several meters from the screen. This means the requirements are completely different and you're comparing apples to oranges.
    I'ved used 1024x768 (nearly 720p) ever since the Voodoo3 nearly ten years ago. When I got the original Radeon 64MB a little later, I switched to 1152x864 (slightly faster than 12x10 and more natural aspect ratio) and then 12x10 when I got a 19" display in 2003. Noone called that "High Definition", because the term wasn't coined yet. We just said that the new cards allowed for "high resolution" gaming. High Definition is just a buzzword invented by the HDTV and gaming console industry because it's easier for people to understand the word "Definition" than "Resolution". "High Definition" on the PC has been around for over 10 years.
  2. Frostex
    Frostex 2[H]4U
    2,143
    Apr 29, 2008
    Funny really, the 30" 2560x1600 model is basically like 4x 1280x800 monitors stacked in a 2x2 grid :D
  3. RadXge
    RadXge 2[H]4U
    2,778
    Aug 2, 2006
    I consider >=1920*1080 to be high resolution.
  4. defaultluser
    defaultluser [H]ardForum Junkie
    12,634
    Jan 14, 2006
    When I was in High School, I drooled over the high-resolution SVGA games (640x480, 256 colors). Four times the resolution of old 320x200 VGA games just impressed the hell out of me. I steadily upgraded, from 800x600 to 1024x768, and finally to a 19" CRT, which I run at 1280x1024.
    Even at work, the screen sizes have remained fixed at 20" 1600x1200 panels for several years. And sure, we have many workstations with two of these panels, but that's really it so far as usability goes: a third or fourth monitor would just be wasted space. The push for more resolution just isn't there, not unless you work with graphics, or with stocks.
    I actually find 1280x1024 very comfortable...with the addition of my HD 4850 plus 8xAA, I see almost no lines, and get fluid frame rates. Resolution and screen size increases just aren't as important to me as they used to be; what I have now is "good enough."
  5. JacobC1983
    JacobC1983 2[H]4U
    2,608
    Sep 4, 2006
    This is not comparing apples to oranges, in both cases we are discussing the resolution of a monitor or television.. the idea of high definition and high resolution is simplymy attempt to set a boundary for the idea of high resolution gaming; and there is no way to compare the idea of sitting distance to the resolution of the said display.. I for one sit the same distance from my 1080p screen and my 30 inch dell monitor for gaming, as i did with my 1600x1200 monitor before it...the idea of high resolution is going to vary from person to person as with sitting distance and monitor resolution
  6. wildfire99
    wildfire99 Gawd
    720
    Mar 6, 2007
    What I still don't understand is why I have Blu-Rays that look stunning at 1080p, then games at 1200p that look only half as good (on a 1900x1200 monitor). The resolution isn't a big factor, but the overall picture is.
    I still consider 1080p+ to be high def, not that it ensures a good looking picture.
    One particular "oh wow" moment was playing Crysis at 1080 on my 40", then plugging in Lost (BD Season 3) and just marveling at how much more crisp and "real" the BD was, in fairly similar jungle environments. There was no comparison in terms of clarity and sharpness, even though both were technically running at the same resolution. There's something much more to the image than mere pixel count.
  7. ADRENALIN_2099
    ADRENALIN_2099 Gawd
    922
    Apr 26, 2008
    but you cant compare a game to a movie/tv show in terms of quality...... of course real stuff will look better then rendered stuff %100 of the time.
  8. Somnambulator
    Somnambulator Gawd
    856
    Apr 13, 2008
    i play 1920x1080 but it's a pretty standard res to me. i still consider it high rez, but only because 16/10 is pretty much the norm these days. 25x16 will be the only high rez soon enough
  9. legcramp
    legcramp [H]ardForum Junkie
    10,829
    Aug 16, 2004
    I thought 1024x768 was a luxury????
  10. sculelos
    sculelos [H]ardness Supreme
    4,690
    Aug 27, 2004
    Really I don't really care too much. I watch video all the time in 480p and it looks fine and play games at 1680x1050 on a 20" Widescreen LCD.
    Honestly the only reason I went from 1280x1024 to 1680x1050 was for the widescreen movies and games. The higher contrast ratio and better colors are just a bonus.
  11. Valset
    Valset [H]ardness Supreme
    6,531
    Apr 4, 2008
    How about a more pragmatic definition sense some people take this too seriously.
    High resolution on a computer monitor can be defined as the resolution that the most mid range cards fail to provide acceptable game play as defined by being able use 75% or better of the graphics options smoothly.
    For instance Bioshock was quite playable but still choppy with my 8800GTX. smooth as silk on my GTX280. mid range card was not quite enough at 1920 by 1200. newer games are worse and require a better graphics card. so for me high resolution started at 1920 by 1200.
  12. Hypernova
    Hypernova [H]ard|Gawd
    2,028
    Jan 16, 2007
    An in game object with 400x300 res texture is going to come out as 400x300 on the screen. One of the reason games these days are so big is due to those large textures. But even then it's not enough to be anywhere close to what the eye can perceive.
  13. R3MF
    R3MF [H]ard|Gawd
    1,803
    Aug 14, 2006
    agreed.
  14. E.R
    E.R Gawd
    631
    Sep 19, 2007
    1920x1200+
  15. AthlonXP
    AthlonXP [H]ard as it Gets
    20,293
    Oct 14, 2001
    1920x1080/1200 with AA turned up.
  16. GibsonEX
    GibsonEX Gawd
    680
    Feb 21, 2008
  17. pizza
    pizza Limp Gawd
    344
    Sep 1, 2008
    Well I consider 1650 x 1080 high resolution. I was really annoyed with all the hype with consoles about being HD or 1080p and games can barely even get out 720p. My current res is 1900 x 1200 but I hope to one day get a 30 inch with higher resolution when the prices come down.
  18. Kangg
    Kangg Ad Blocker - Banned
    1,994
    Jun 8, 2004
    1920 x 1200. My screens native res.
  19. necrophile
    necrophile [H]ard|Gawd
    1,243
    Sep 6, 2008
    why include AA?
  20. svet-am
    svet-am [H]ardness Supreme
    5,146
    Jan 6, 2003
    i'm a bit old, but I consider anything above 1280x1024 to be "high resolution". Sure, I enjoy larger (I have a 5040x1050 rig at home) displays, but I think of myself as being far above the cure in that regard.
  21. AthlonXP
    20,293
    Oct 14, 2001
    gotta throw some eye candy goodness in there right??
  22. wildfire99
    wildfire99 Gawd
    720
    Mar 6, 2007
    My point really was that, regardless of the resolution you play at, you're always going to be hampered/hindered by the lowest common denominator on screen. That thus far appears to be texturing as you wisely mention (id's supertexturing aside since it has yet to prove itself), followed closely by crude object geometry.
    I can play Crysis at 1920x1080 or even 2560x1600 and it's never going to look anything like reality at half the res. That's what bugs me most about high res gaming and the graphical horsepower required to run it. Even if the pixels are tiny the image still sucks too much of the time.
    I saw all the screenshots of Mass Effect and thought they looked amazing. When I fired it up on my own rig at 1920x1080... well it didn't look any different from last year's games or the games from the year before that, aside from some respectable art department work on general textures.
    Since I had performance problems on my 8800GT, I switched back and forth between 720p and 1080p. I couldn't tell the difference.
    I don't really have a point to what I'm saying, other than after decades of PC gaming (wow, am I that old already) I still haven't had any epiphanic moments where a game (the REAL game, not screenshots or pre-rendered demos) crossed that line into "damn, this looks real." I'd rather concentrate on higher quality over higher resolution. I'm probably going blind at my age but I'd rather have a good IQ game at x768 than one with crap texturing at x1200.
  23. Mr. K6
    Mr. K6 [H]ardness Supreme
    5,052
    Mar 23, 2005
    Well said and very much my sentiments as well. To me, the higher resolutions don't add anything to the experience, and that's why I stay at 1680x1050. Although I must admit, when I played Crysis on Very High for the first time, and ran through the forest with the light through the trees casting shadows, I did say "holy s***!" :p
  24. edifyingkarma
    edifyingkarma [H]ard|Gawd
    1,465
    Mar 8, 2008
    I agree with most in saying that 1080p and above is true "high" res gaming. I must disagree with other saying that the resolution doesnt add realism to the game. I run 2 8800GT's in SLI because you need more power to run resolutions equal or greater than 1920x1080/1200.
    Mass Effect at 1080p is AMAZING, and toning down the resolution is going to make a difference.
  25. Mr. K6
    5,052
    Mar 23, 2005
    On the same monitor, probably because splitting the cells is going to make it look like hell. On a native 1680x1050 monitor, not enough for me.
  26. FinalAura
    FinalAura [H]ard|Gawd
    1,123
    Jan 10, 2008
    Anything above 1280x1024 and 1440x900, I consider high resolution.
    I run 19x12 now on a 24" monitor.. The amount of real estate is nice, but coming from a 1440x900 monitor and a 8800gt, my 8800 doesn't feel up to par anymore. I miss the smoothness of the lower resolution, but gaming on a bigger screen on a higher res does look nicer.
  27. rincewind
    rincewind Gawd
    888
    Sep 21, 2004
    High resolution means little to me when it comes to gaming. By and large there isn't a great deal of variation in pixel pitch among desktop TFT's (19-inchers are the worst), so as long as it's running at native res I'm fairly happy. Ideally I'd opt for 2048x1536 on a quality CRT (a 22" has a usable display area which is slightly smaller than a 19" TFT panel) - it's high res, but more importantly the pixels are tiny. I'm often tempted to get a nice 22" FD Trinitron so I can game at 16x12 with vsync enabled at 120Hz (and run older games without horrid downscaling), but then I recall their massive footprint/weight and how overburdened my desk is already :p
    Within the confines of resolution alone I'd vote for 2560x1600 as that suggests a 30" WS and those things are sweet :D
  28. Valset
    6,531
    Apr 4, 2008
    I did the same (except I got the 28") and my fancy smancy 8800GTX just could not make any of the newer games feel smooth. A GTX280 solved that problem.
  29. Term-X
    Term-X 2[H]4U
    2,409
    Apr 21, 2001
    Well for me it's 1360x768, simply because it's my TV's native resolution. But I would probably say otherwise, 19x12
  30. sardonic.n7
    sardonic.n7 Limp Gawd
    273
    Oct 16, 2006
    2560x1600.
    1920x1200 is pretty much average for most enthusiasts these days.
  31. Frostex
    Frostex 2[H]4U
    2,143
    Apr 29, 2008
    I actually have an old Iiyama CRT which does 2048x1536 over 19", best dot pitch monitor I have ever used, quite amazing really, doesn't really need AA at all, it's so sharp.
  32. infinity4life
    infinity4life n00b
    61
    Dec 23, 2005
    Because of teh jaggies!!!! :rolleyes:
    Seriously though, I never understand AA/AF/etc... with resolutions above like 16x12. You can't really see any difference
  33. necrophile
    1,243
    Sep 6, 2008
    yes, you can, you can see a ton of jaggies at any res. my point was that AA doesn't have anything to do with resolution but obviously the poster would rather have 19x12 with AA than a super high res without and understandably so.
  34. Valset
    6,531
    Apr 4, 2008
    I don't need insanely high AA but I like to run 4x anytime I can help it. it makes a noticeable difference to me.
  35. necrophile
    1,243
    Sep 6, 2008
    Oh and same goes for AF as well but worse. Have you had your eye's checked recently?
    That is a serious question.
  36. matrix563
    matrix563 [H]ard as it Gets
    19,036
    Sep 1, 2006
    1920x1080 or 1200 is fine by me :)
  37. Slade
    Slade 2[H]4U
    2,539
    Jun 9, 2004
    1900 by 1200 is norm... anything higher is "hi res" heh
    though I don't mind gaming on my 1080 37 inch...
  38. MartinX
    MartinX One Hour Martinizing While You Wait
    7,187
    Jan 23, 2003
    I consider 16x10/12 and above to be high definition.
    1280x1024/720 is what 17/19" monitors come in, and that's pretty mainstream/standard at this point.
  39. guezz
    guezz [H]Lite
    70
    May 11, 2006
    1920x1080 or more.
    1680x1050 is pretty much standard now.
  40. BravO)))
    BravO))) [H]ardness Supreme
    6,177
    Jun 16, 2008
    I played on a 1400x900 for two years, recently switched 1920x1200 gateway. The difference between the two is a bigger image with more detail. You would have to compare these resolutions at the same size. 12x10 on a 19" vs a 16x12 on a 19". You will see a big difference in the quality of detail.
