Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ahh, noticed a difference in the model number...so it's the same card in a different box? no changes to the setup or anything. I just thought there were some versions of certain cards that might be able to be modded or something.
The cards should be IDENTICAL. However, companies are known to put the better overclockers in retail boxes. Do you mean modding to a 9800XT? I think all the pros can be soft-modded to do that.
