So tell me... i'm curious
Hi guys,
Remember the change from Netburst to Core a couple of years back? I know it was a big jump but i'm curious of how much. Was Netburst really that bad? i know it was inefficient but how would the best Netburst setup equate to todays line of CPUs?
2 x Xeon 5080... Yes this is two of the best Netburst chips... never heard of them? They're just Pentium Extreme Edition 3.73ghz with SMP enabled so you can use them in dual CPU configurations. Now by doing this you get 8 threads available @ 3.73ghz with a total of 8mb cache (2mb per core). They also used a 1066mhz bus since they're based on the Extreme Edition chip.
Any idea what sort of Core 2 chip this would equal? Surely it has something going for it?
Just curious :)
Regards, DrunkenSensei91
Well, my brother has a single 65 nm Pentium D at 4.2 GHz, and it can barely keep up with my Core2 Duo E6600 at 2.4 GHz in most tasks. When I start overclocking aswell, to say 3 GHz, the gap widens quickly, as C2D scales much better.
SMT might improve its performance by a few percent, but I doubt it'd be very impressive (perhaps 20% or so if you're lucky).
And then there's the HUGE power consumption (a Core2 Quad uses less power than a Netburst dualcore).
So well, high-end Netburst can still deliver 'acceptable' performance by today's standards, but performance-per-watt is horrible, and it's by no means competitive with today's high-end in terms of absolute performance.
Yeah i remember people always complaining about heat issues with their Pentium 4s and Pentium Ds... Netburst always had too much power leakage which just ended up as heat. Core is definately far more efficient per watt and clock than Netburst too.
I remember when Crysis was released the Intel staff would brag about how Crysis was closely developed with Intel to take advantage of Quad Core which it does well... and by saying this they no doubt mean four threads. Does CryEngine2 scale further and support 6 and 8 threads for example?
I think it would be interesting to see how my example configuration above would perform in an SMP optimized application like crysis... Sounds like it wouldn't be too bad if all cores were utilized... and if something could use all 8 threads then maybe things would become even more interesting in terms of performance for the dead Netburst platform.
Are you really looking for the equivalent, or is something better okay? Because most C2D CPU's would be better in every way.
A new motherboard with a Q9550 would smoke that setup, esp. with mild overclocking.
