Hi guys, today I picked up a stacker. this is after heavily pondering the aerocool masstige and the Tt armor.
right now i use a BIX2 with silverstone fans, no shroud. I currently have a 120mm BI pro + 2 shrouds sitting around and I think I may try it in the loop.
My setup consists of not much restriction at all, besides the 3/8 tubing
This is where I was thinking the extra rad wouldnt hurt as my loop isnt solely dependent on high flow to be good.
loop consists of an asetek waterblock (simple dimple in the middle of block) and a AC cuplex evo r1.1 ( think copper spiral going up) and my pump is an Aquaxtreme 50z.
anyway probably going to use it since I really would like to see if it would make a difference, my question is what would be the best place to put it. I am thinking either right before the BIX2 making it in series or right after the cpu block, before the gpu block. maybe lower gpu temps?
pic, up top is the BI pro. right now I got a BIX2 there, its just the pic isnt current.
thanks peeps.
thanks peeps.
