- Jan 28, 2002
SO I bought a Dell 2007FPW and the damn thing turns blue after using it for about an hour. I didn't buy it from dell, but I was new and came with a 1 year warentee. I hope I can return the damn thing.
Perhaps a change of vga cable (better quality) is in order, you cannot buy a simple converter of vga to DVI as vga does not carry the digital signal (analog vga signal is however carried by DVI). A vga to DVI converter would be very expensive (or not worth) and not to mention the noise generated from digital to analog to digital.Whitebread said:No they did not. The guy said that I shoudl be fine with dell or I can call him.I hope he didn't screw me.
Luckly for me, though, the monitor seems to be ok on DVI. So if he doesnt respond, I will still have a working monitor, I woudl just need to get a new vid card or VGA->DVI converter. I didnt want to spend the extra cash but whatever.
