So it's assembled and running...now what?
ctbook
I just built A7N8X-Deluxe, AMD 2500 Barton/w stock HSF, 9800 Pro AIW in an Antec Sonata case. Is there some kind of immediate mods I should make and what sort of stability test it should put it through and any other things I haven't thought of?
Run it through Prime95 or something. Run Memtest, find a burn in program and let it run for 24 hours. JOIN THE HORDE!!! But wait, theres more...you can play awesome games now too. Have fun with yor new rig.
Does it boot right? Installed Windows?
OK, after that, install all the drivers in Windows. If you want to get the best performance, I reccommend the Tweak Guide here in Gen. Hardware and www.tweak3d.net . After that, test the stability by running some simple apps together (word processors, music software etc), then play some big games that test the hardware. Any defects in the assembly process are usually found that way.
Post back if you have any problems. Best of luck.
download speedfan while doing prime 95 to check if your cpu is overheating or anything.
4k,
your old comp reminds me of what I have now...a Intel MB carrying a Celeron 333 OC'd to 550 with a Voodoo 3 2000. 10 gig HD. This new comp I built will so bury it. Man, how did I go this long...? It's been like 5 or 6 years with a Gateway that originally had a PII in it. Learning and learning.
ctbook said:
4k,
Yeah, i've got the old P3 running as stable as its ever been... it still works pretty well, but i've been looking for an upgrade for months now. The only game I play on it is Unreal Tournament... :rolleyes: 40 frames per second is pretty good for my machine. This baby's 5 years old, and it is starting to show its age. Its in my bedroom, I usually post at my school... their broadband, my bandwidth! Mine's not connected to the net (yet...)
