So is my mobo retarded??
I'm having problems with my MSI nforce 2 board. I'm using a MSI K7N2 Delta-L mobo. For one, I cant get my 2800+ to run at 166mhz. It will start to load windows then crash and reboot. The fastest I've been able to get it is 166mhz. It also refuses to post after a few crashes and the diagnostic leds on the back tell me that its a memory problem. I swung by a computer show today and picked some some new sticks to test it out and it gives me the same error. I've reset the cmos several times and even pulled the battery. I reset all the jumpers to run at 100mhz and i can boot and start to install windows, but when i am unable to copy some system files. I've tried multiple copies of xp pro, legit and illegal, to see if any of them will work. Is my mobo the source of all my problems. My CPU is being cooled by a Thermaltake Silent Cool. I've tried barebone starts and tried all four of my memory sticks and still no go. The only cards that I'm using are my Radeon and my GTXP, but i dont know why that would affect and of the files being copied. I'm really frustrated and clueless at this point and any help is greatly appreciated. thanks.
Well, K7N2 Delta-L isn't a terrible board, so if there's anything wrong with it, it's one of those rare hardware faults that sneak into a few the production process. However, I'm inclined to wonder if you shouldn't be checking things such as the CPU settings and memory timings. For one, does that CPU have too little/too much voltage? Are the memory timings too tight for the memory to handle (and admitedly this is a little iffier since you tried different memory sticks -- one of them probably should have worked...) Also, this one is the Ultra 400, so, if you are putting in two sticks at once, they are trying to run in dual channel mode, so be sure they can handle that.
Most of all, I'm thinking you should check the CPU. CPU can do all these things. Is yours MEANT to run at 200 FSB? Since I've only played around with the mobile bartons, I can't remember what stock FSB was for the non-mobile, though 166 doesn't sound impossible to be stock for a 2800+ to me. If so, you're overclocking it... If not, then, sorry for saying something so silly... Anyway, see that it has enough power, whichever is the case. Also, too much power would have it running really hot and less stable if it's not cooled well enough. It's a good heatsink, but, if it's not on there quite correctly the CPU will be unstable regardless. (I've done this before. In fact, I once installed a HSF backwards so that it wasn't QUITE covered all the way. The CPU was probably damaged, I don't know, the heatsink broke off, so I never found out since the cpu was DEFINITELY damaged after that...)
