no leaks, thus far...
#1 .
Although, on the fillport of my res see res here should there not be an O-ring for this little black plug?
I can use some paper towel under my fingernail to soak up a little bit of liquid in there, when it's screwed down tight.
Anyone happen to know for sure if there's supposed to be an O-ring?
#2.
Looked for a leak testing guide, no luck. Looked for a bleeding guide, no luck.
Now, I do understand that you dont want bubbles in yer loop ... but how on earth does one get all the air out of this type of resevoir?
I've tried tipping it so that the air bubble(s) are around the hole... and adding fluid. Naturally, I can only add so much, before the fluid would much rather flow out the hole than up and around it (displacing air as it went) ...
Is it just not feasable? And... is it okay to have a little air in there? I mean, i've seen pictures of people with Aquatubes 80% full...
Any help would be appreciated, greatly
#1 .
#2.
