So i'm finally seeing red, 4870x2
iceredwing
After years sticking with the green time, I finally purchased my first ATI card. Technically traded, but semantics aside...
a few questions for those that have this card.
Is it normaly for the first core (core0) to be this hot? When i leave the fan at 25% it can reach 80 degrees idle while the second core (core1) is around mid 40's. If i run the fan at 40% it will lower the first core the low 50's (which is more acceptable), I wasn't expecting one core to get that hot while the other was that cool.
Is there some reasoning to why core0 is that much hotter?
Secondly... holy hell... 100% fan speed is unreal. Anyone else finding the noise that it produces to be a little at the insane side? Perhaps i've been watercooling my parts for too long, but damn I don't recall my old video cards (always had high end cards) make that kind of noise.
I think that is a common problem with that cooler. The 2nd gpu gets cooled with fresh air so the temps are normal, but that first gpu only gets all the hot air from the 2nd.
You can either replace the cooler with something that has a more open design and two fans or something, or do like that one guy did on here and cut the top off and put a fan over each gpu.
Some of these cards have far less discrepancy in temps between the two cores than others. It's really just the luck of the draw. That said, I never leave the fan below 35% at idle. It's still quiet and keeps temps down to the low 50's for the hottest core. Anything below this fan speed and the card gets a little too toasty for my taste. At load while gaming, I set the fan to about 65% which is a decent compromise between cooling and noise. And yes, at 70% and above, this card is obnoxiously loud. Fortunately, you never have to run this fan at 100% to get good cooling.
ATI does'nt seem to listen very well to customer needs. They seem almost arrogant and indifferent to the end user's complaints about heat on the entire HD series. It's been proven that a 35-38% fan speed drops the temps to around 47-50 degrees idle without being objectionable noise-wise on the cards...yet despite the info... they keep releasing driver after driver with the same "stupid" default low speed. Makes you want to slap somebody upside the head.
that is very true, I have no idea why they want to set the fan to such low, and somehow for my 4870, the fan doesnt even want to go up when its extremely hot :confused:
but manually set ti to 33-35% does help a lot, no heat problem, and no noticeable fan noise.....
so I am still happy with it..
Actually ATi listened to the customers as in the past the biggest complaint was noise from the fan, so they designed a system that was capable at running at high temperatures in order to keep the card quiet. So now that it's quiet there is a new set of complaints that the card is to hot so then ATi released drivers that allowed for manual fan control so now the people who want it quiet have it quiet, and the people who want it cool have it cool.
Why are you leaving the fan to idle at 25%? The factory default is 27% (1290RPM) which is just quiet enough but still manage to keep the 1st GPU under the fan ramp up threshold of 77C under normal situations. Personally since I have a pretty quiet system set up during idle I can hear the fan it it reaches 28%.
There is really no need for manual fan control as the default auto control keeps the GPU under 95C most of the time (and that's due to my poor case air flow), and the card is designed to work under that kind of stress.
I imagine your 4870x2 sounds anything like my sapphire 4870 1gb, like a broken vacuum at 100%, its pretty unreal. Thankfully I never have any reason to run my card over 50%, as the temp has yet to rise above 60c.
i run mine at 50% percent speed at my GPU 1 idles at ~ 37 C and GPU 2 ~ 32 C.
Im not sure about in game, but it does get hotter, but to me, 50% isnt that loud, and it keeps the temps low enough for me to be satisfied with it :)
actually i don't leave them at 25% all the time. I simply tested it at those speeds since that was its lowest. I have never had a card at idle where the fan was running and it would reach those temperatures. Mind you that I did not spend 1 or so hours at 25%, i believe it would reach 80C within 2 minutes at 25%.
And with regards to the fan, when I put it at 100% my girlfriend thought I was playing with my RC helicopter inside the house
If anything at least replace the thermal grease on the 2 cores. I did this and the shroud mod and this alone dropped the idle temp at 29% fan speed from 71c to 51c. The stock paste peeled off with my thumb!!!
yeah i might end up doing that, was hoping to save it (since i'm running out) for when I get my waterblock. But if it improves it that much I should do it
