So, I'm an idiot - Flashed wrong bios (NF7-S)
Dizj
Well, title pretty much ses it all. I did a "next next next" job and ended up downloading the 1.0 + 1.2 BIOS update and flashing it into my v2.0 board (using flashmenu, plz don't laugh). I restarted and got a the Siren, cleared the CMOS and get no beep(s) now, I get alot of HD activity then it just stops.
Feel free to abuse me for my stupidity..
Anything I can do bar by a new bios/board or something (asuming I can even do that)?
Any help is very much appreciated. Thx.
I think you are out of luck. The question that might help is "Are BIOS chips hot-swappable?"
If they are, then you can boot off of a good chip (if you have a friend with the same board), boot will a bootable disk with the correct BIOS and then swap the BIOS chips with your bad one and flash. This will only work if you can swap it out while the power is on without messing up the good BIOS chip you have.
Good Luck and I hope you find a resolution.
Is the chip removable? If so see if anyone locally has an eprom burner or something. ( I have no idea what kind of chip it is though). Is it possible to order bios chips through the manufacturer?
kk, thx for the tips!!!
I may try hot flashing tomorrow..
I have an ASUS A7V333 mobo which LOOKs to have the same kind of BIOS chip, I'l try find out for sure, unles it just fitting is enough?
So if they are compatable, I would need to:
Boot up the comp with the ASUS motherboard (into DOS).
Replace the BIOS in that with my bad flashed NF7-S bios.
Flash it corretly with the Abit flashing soft.
Shut down.
Put chips back in correct mobos.
Breath a sigh of releif.
Thx again.
when you turn on the system, can you see the floppy drive seeking? if it is then the boot-block is still working and its looking for a floppy with a bios image to flash, i saved an old 440bx board that way.
I did the same thing you did. Except it was kind of asus' fault because i followed their instructions exactly, but they left out a step. So, when I got an error message saying it was the incorrect file type or whatever, I just said BS and hit enter. Needless to say, my computer stopped working. I was pissed so I called Asus and they gave me an address to send my bios chip to. They reflashed it for free and it only cost me a couple cents in shipping. The best news it, it worked and they flashed it with the updated bios. Sucks that you are out a computer, but you'll make it.
Hot swap, haha let us know if that works out for you, I know a few gurus I could impress with sucha story.
There's got to be a better way to do things than bios chips. I took a chip out of a board once and when it was time to put it back in, I couldn't remember which way I took it out. I put it in the wrong way, smoke came out and the "phoenix" sticker melted off. A friend of mine had an identical MB which gave out on him, so I took the bios chip off of his and popped it in mine, worked fine.
for the future, the chip will have either a cut corner, arrow, or dot in one corner... That's your reference point. Similarly, there should be a distinguishing mark on a corner of the socket. Either a cut corner, dot, arrow, or something silk-screened on the pcb.
