As the topic says, I managed to completely lock up Windows 7 (RC 7100), only the reset/power button could get the system working again.
I've been using the RC for months, and have been very happy with it (Home Premium already pre-ordered), and I've had no problems with crashes, nor seen a single blue screen untill now.
The problem isn't with Win7 per se, the problem is with my LG BD/HD-ROM/DVD-RW SATA drive, and a particular brand of DVD-R disks. If one of these disks is inserted into the drive (either a blank or a pre-recorded disk) the drive light flashes, and if an attempt is made in windows to access the drive, or if its left alone for more than a minute the computer just stops responding (including ignoring the eject button on the drive) ctrl-alt-del won't work, and if the computer is left long enough it may notice explorer has stopped responding and ask if I want to end it, but the dialogue box stops responding if you pick an option. After a reboot the event viewer says the disk had a read error.
The Windows XP partition on the same machine behaves in the same way. DVD-R's of a different brand work fine.
The same disks in my old computer, with a fresh xp install and my old drive, are accessed in seconds.
These disks always worked perfectly fine on my old NEC DVD-RW PATA drive, so the obvious solution is to either not use the disks, or change the drive (Which I plan to do, its still under warranty).
But 7 is touted as the 'most stable windows yet' and all that, even if an optical drive goes crazy, this new 'bulletproof' OS should just say 'the disk cannot be read, not fall appart so badly.
My concern is, what if the replacement drive takes a sudden dislike to a different brand of media?
Any of you guys got any suggestions as to how I can make it fail more gracefully if it happens again?
