I have a 1000W UPS powering my computer, monitor and router. I sometimes experience power shutdowns so the UPS gives me enough time to save anything I am doing. However today I think for the first time there was a power shutdown while I was playing a game. My PC "restarted" and showed this message,
Now the power is still out and the PC is still running. I pressed F1, got into the BIOS and then got into Windows as well all the while the power is out and UPS is running. So the UPS can't be at fault here can it? Just to make sure the UPS isn't getting overpowered I later ran a stress test, turned off my monitor and then shut off power for a few seconds before restoring it. I still got the same screen as above. Just to remove any doubt about the UPS' capacity being enough for my PC at load I plugged in my speakers to the UPS, full on blasted them and cut off the power. For 10 seconds everything was going smooth the speakers, the monitor and the idle PC playing music. I restored power after that so I suppose the UPS really is off the hook I would think.
If the power loss occurs while the system is not under stress nothing happens and everything keeps running smoothly with the monitor on till the UPS has the juice.
However if this is just a PSU problem then why is it never a problem when there is power? I mean if a PSU is underpowered or malfunctioning then it should show problems whenever the system is stressed which I have never ever experienced yet. If there is a power loss then what does that have to do with the PSU? But then the UPS should have zero issues in terms of pure power with my computer at full load without the monitor in the equation.
So could it just be that the ASUS board is being "over smart"? Is it safe to try to see what happens in the event of a power loss after turning off ASUS anti surge support?
I have a Corsair GS 600W PSU and my PC is just a single GPU configuration with GTX 1070.
