So I got Raptor150
I was going to disable NCQ, but apperantly its not possible. I have DFI nf3 250gb mobo and in the IDE settings Enable Command Queuing and Enable Read Caching are both there but they are greyed out cant select/unselect them, so wtf??? What did I miss? Does my raptor not support NCQ? Does NF3 not support NCQ? I thought NF3/4 both support NCQ? I just formatted - Am I using the wrong chipset drivers? Was I Supposed to install some software with my raptor since I got it oem from newegg? Help please, im lost...
Do you have the gamer version with the window, or the server version? I seem to recall that the server version is the only one with command queuing.
Yep, I just reflashed my mobo with latest bios from DFI, still same problem, should I try a different set of nforce drivers?
Ok, i went to DFI forums and searched, and apperantly there is no NCQ support on the nF3 chipset.
