So I can't decide on a case...
So I'm building a computer and I'm looking for input on a case.
Currently I'm thinking I like so far:
this case
http://www.newegg.com/Product/Product.asp?Item=N82E16811129154#DetailSpecs
with this PS
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
the problem is this one looks kinda small (well small in comparison to the next one)
but I also like this case
http://www.newegg.com/Product/Product.asp?Item=N82E16811171080
it's bigger, but I will probably put in the other power supply, it's also a lot more expensive and though I like the design, the size, the slide out mobo rack the side air duct, frontside audio/usb/firewire, I'd replace the 80 fans with 120s though
I don't like the leds though and the extra cost (extra for the PS) plus some reviews are complaining about hinges on the door(weak and have live wires in them) and screwless clips (clips can be removed for standard screws)
Essentially I'm looking for a cheaper but similar case design to the xg dragon case, anything similar or advice would be most appreciated. I'd probably get the dragon over the p180 if it didn't come with a PS, I can't find a vendor that sells them without and because of that I'm leaning to the P180.
I also started looking into this:
http://www.newegg.com/Product/Product.asp?Item=N82E16811173008#sctNav
