So I bought a cheapo.
cvfd1615
Hello,
Picked up a computer at a yard sale today 350mhz P2 w/ 128 Ram HP and it has Win 98 hell I gave $5 bucks for it.
Well seems like this computer doesn't have hardly any drivers on it at all. I have ADSL Here at home and want to update it but I can't get the USB going on it. It detects the device but that is really about it.
Can you advise what I can do to get this computer going enough so I don't have to live thru painful dial up to update this computer.
Do you feel the Windows Update will work to get the drivers.
I do but I'm unsure which drivers I actually need so I prefer to just put in CD or whatever and let it find it on its own. A Win 98 or SE CD
Have you googled around for the drivers? Tell us the model number, we might be able to help you find something.
Also, you might just ditch the USB and hook the modem up via Ethernet. Ethernet usually works better anyway (well, in my experience).
That's assuming the PC has built-in Ethernet...a lot of older PCs do not...
If i were you i would prolly try to get a linux distro up and running on it. Xubuntu would be a good option. It should have the drivers you need.
That's true, it might not. I was assuming since it had USB, it probably had Ethernet... But that's a very real possibility!
I second this option... however I would recommend Zenwalk. :)
Computer is a HP Pavlion 6000 Series but don't remember the exact model since I'm here at work
It has a 56K modem in it but it does not have ethernet Nic Card...
I really wanted to set it up to do wireless w/ a Netgear USB thats why I was inquiring about it.
I have a person going to let me borrow their Windows 98 CD and hopefully it'll get the necessary drivers off it to get the USB going and then do the windows update to get everything up to snuff.
I know its a POS but I might make this a storage computer or print server or something since I have 2 printers - A laser and a inkjet for pictures and set it up something like that -
Not entirely sure yet.
Win98 doesn't contain proper USB drivers you need to download them from the manufacturer site if they even have them anymore. Earlier every USB memory stick etc. came with their own driver CD for win98. Lose the disc - no go in w98 as they were not provided through downloads.
Considering what you can actually do with a P2 350Mhz I third the notion of running a linux distro on it. Office/Internet browsing all the way.
Went ahead and bought a PCI Wireless Card last night and will install it to add it on my network...
Should do what I want then
So my question is...
Why put USB into a computer that isn't supported by its O/S
it is semi-supported in 98 B you just need a specific driver for every device... not really plug and play
QFT. Windows 98 "supports" USB but every USB device must be "installed" using a driver CD that came with it. It doesn't just auto-detect that a USB flash drive is a drive and mount it for you or that a DSL/cable modem is in-fact a network device. A pain yes... but meh, it's and old OS. :)
Put Ubuntu on it instead of 98. Unless of course you plan to play old games on it... I still have a P200MMX around for Mechwarrior and some of the really old games. Nostalgia!
GoD I hate old PC's.
Drivers are to be had on HP's site if it's they're make, and they usually keep em all on line.
If you brought that "thing" into my lab I'd prolly tell you to chuck it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=20&lc=en&cc=us&dlc=en&product=59329&lang=en has the HP-provided drivers for the built-in devices. Of course, that won't help with any additional devices they added/you would like to add. For those, you'll need drivers from the device manufacturer - whether that be an add-in network card or any USB device...
http://h10025.www1.hp.com/ewfrf/wc/...c=en&cc=us&dlc=en&product=59329&os=20&lang=en has the various specifications...
The chipset is the Intel 440BX: http://downloadfinder.intel.com/scr...ame=Windows*+98&lang=eng&strOSs=17&submit=Go! has the chipset drivers for you to install, in case nothing had been...
