I read my p35-dq6 manual, and the way I understands it is that you hook the two drives(say i'm doing RAID0) to sata ports with the same controller. And then you go to ur BIOS setup I think and you enable raid and then sometine during POST you hit some keys to go into RAID configuration utility......there your drives will be detected and you can set them up as RAID0 for example.......
is this almost right?
And what is software RAID as opposed to hardware RAID ? is it the same issue with software/hardware modems ?? with the hardware option being the better one of course? and that's because you have a hardware that is dedicated to control the array instead of taking some cpu power to simulate the function of the controller?
Can any system run RAID by downloading a peice of software, no right?
