So coolbits
IanSMK
thats the prog i need to oc my 6800 gt leadtechs tommorow? and i would like to monitor the temps of my cpu, mobo, case, and video card with the best program..help
Coolbits 2 can OC and check temp. You need something like motherboard monitor for the rest.
For CoolBits 2 you just need to add the following information to a new .txt file and then save the file as CoolBits2.reg. After you do that, double click on the file and it will be added to your registry and unlock the hidden features in the nVidia drivers.
REGEDIT4
; Coolbits 2
; >> Installation File
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NVTweak]
"NvCplExposeWin2kDualView"=dword:00000001
"NvCplTvLocaleAutoDetect"=dword:00000001
"NvCplAllowForceTVDetection"=dword:00000001
"NvCplEnableActiveApp"=dword:00000001
"DisableApplyColorsAtStartup"=dword:00000000
"NoMenus"=dword:00000000
"OverlayPageState"=dword:00000000
"CinematicPageState"=dword:000000ff
"NvCplThermalSettings"=dword:00000020
"NvCplEnableAppProfilePage"=dword:00000001
"NvCplEnableScreenMenuPage"=dword:00000001
"NvCplCustomResConfig"=dword:00000000
"NvCplEnableAdditionalInfoPage"=dword:00000001
"NvCplDisablePerfQualPage"=hex:00,00,00,00
"NvCplEnableAGPSettingsPage"=dword:00000001
"CoolBits"=dword:ffffffff
"NvCplEnableOverlaySpanControl"=dword:00000001
"TwinViewCapsOverride"=dword:00000001
"NvCplEnableDesktopOverlapPage"=dword:00000001
"NvCplEnableTroubleshootingPage"=dword:00000001
"NvCplDisableRefreshRatePage"=dword:00000000
"NvCplDisableRotateAngles"=dword:00000000
"NoPages"=dword:00000000
"NvCplEnableClearViewPage"=dword:00000001
"NvCplEnableFanControl"=dword:00000003
"NvCplEnableFrameSyncPage"=dword:00000001
"NvCplEnableHardwarePage"=dword:00000001
"NvCplEnablenForcePage"=dword:00000001
"NvCplEnablePwrMzrOnDesktopMenu"=dword:00000001
"NvCplEnableRotationColorSettings"=dword:00000001
"NvCplNvThermPage"=dword:00000001
"PowermizerPreferences"=dword:00000000
"QTwkEnableModeChangeWarning"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\OpenGL]
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\OpenGL\Debug]
"ShaderObjects"=dword:00000001
If you want to keep the gaming profiles tab you need to use the original coolbits.
The registry entry i just gave for CoolBits2 has the Application Profiles.
You just have to change:
""NvCplEnableAppProfilePage"=dword:00000000"
to
""NvCplEnableAppProfilePage"=dword:00000001"
Notice how i already did that for you. :)
