so as i asked in another thread
what is the difference between the p5q pro, p5q turbo, and the p5q pro turbo. then i mentioned that on asus site they dont list the p5q pro. and on newegg i was about to purchase one and i see they say the p5q pro turbo has replaced the p5q pro, so it seems this beloved board has been discontinued
P5Q Turbo
P5Q Pro Turbo
P5Q Pro
Look at the pictures side by side, it will make it easier for you to see the differences in the heatsinks used and positioning of components on the boards. I did notice the P5Q Pro has 1 extra sata than the rest, and the p5Q Turbo has different PCIx1 positioning/ 1 less pcix16 and the IDE positioning is different. I couldn't tell you the difference in performance though.
I awensered this, by stating the best way to do this is just compare then directly at the ASUS site. Since this has not been done I will try and do it.
memory support
p5q pro
4 x DIMM, max. 16GB, DDR2 1200 / 1066 / 800 / 667 MHz, non-ECC, un-buffered memory
p5q pro turbo
4 x DIMM, Max. 16 GB, DDR2 1300/1200/1066/800/667 Non-ECC,Un-buffered Memory
p5q turbo
expansion slots
p5q pro
2 x PCI Express 2.0 x16 slots, support ATI CrossFireX™ technology at x8 link
(PCIe x16_1 blue, PCIe x16_2 black*)
3 x PCI Express x1 slots
2 x PCI slots
*PCI Express x16_2 slot (black at max. x8 link)
p5q pro turbo
2 x PCIe 2.0 x16 support ATI CrossFireX™ technology at x8 link (PCIe x16_1 blue, PCIe x16_2 black*)
3 x PCIe x1
2 x PCI
p5q turbo
1 x PCIe 2.0 x16
3 x PCIe x1
2 x PCI
storage
p5q pro
Southbridge
- 6x SATA 3Gb/s
- Intel® Matrix Storage Technology with RAID 0, 1, 5 10 support
Marvell 88SE6111
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
Silicon Image Sil5723 (Drive Xpert technology)
- 2 x SATA 3Gb/s
- Supports EZ Backup and Super Speed functions
*Drive Xpert function is available only when the hard disk drives are set as data drives.
p5q pro turbo
Southbridge
5 xSATA 3 Gb/s ports
Intel® Matrix Storage Technology Support RAID 0,1,5,10
JMicron® JMB361 SATA & PATA controller:
1 x Ultra DMA 133 / 100 / 66 for up to 2 PATA devices
1 x External SATA 3Gb/s port (SATA On-the-Go)
Silicon Image Sil5723 (Drive Xpert technology):
2 x SATA 3Gb/s ports
p5q turbo
Southbridge
JMicron® JMB361 SATA & PATA controllers:
lan
p5q pro
currently do not info on
p5q pro turbo and p5q turbo
Atheros® L1E Gigabit LAN controller featuring AI NET 2
audio
p5q pro
Realtek ALC1200, 8-channel High Definition Audio CODEC
- Support Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
- Coaxial S/PDIF_OUT ports at back I/O
- ASUS Noise-Filterin
VIA® VT1708S 8 -Channel High Definition Audio CODEC
DTS Surround Sensation UltraPC
- Support Jack-Detection and Multi-Streaming
- Optical S/PDIF_OUT port at back I/O
- ASUS Noise-Filtering
Hopefully this helps. If you want to see a direct side by side comparison go to www.asus.com then global and then choose your models and add to the compare list.
