So, 20" is better than 22"?
ml1209
Since they both have the same resolution 1680 x 1050, the smaller LCD would have sharper images?
Or can you not tell?
Pixels are smaller, and depending on what model you get, the panel can be much higher quality on the 20".
Really? So would it be worth it to get a 20" instead of a 22" for a better gaming experience? Which models are "much higher quality", exactly?
Well S-IPS is the best, but its only found in some NEC (can't remember the model number, but I think it might be discontinued anyway), and the Dell Ultrasharp 2007FP/WFP. Its pricey though, as they retail for $300-$400.
For gaming, anything with a slow response time is fine, and 22" will work, you will just need to use more AA.
The higher quality monitors are more for graphic design than gaming (though they are great for gaming too).
I don't know about gaming but I like the 20' better for photograpy. I notice the larger pixel pitch since the 22" is same as 20" expanded (its why they are cheaper - easier to make - manufacturers like the expaned resolutions like 19" 22" etc). However, for reading print a lot of people like the expanded pixel pitch for the larger fonts that result.
The NEC he's talking about above is the 20WMGX2 which can still be found at Newegg but only in white. The Dell 2007WFP is the second best 20" but there is the lottery to consider....there are also a few P-MVA panels found in some Acer models and I would prefer that to a TN panel 22".
I wonder if that 22" Lenovo will be S-IPS.. only reason I'd ever see in buying it over a 24" 1920x1080 monitor.
If you end up getting a 20 inch remember the text will be quite small but set it to 104 custom DPI in Vista and you are good to go.
