Stealth5325
- Dec 27, 2000
Someone has to know this, and I'm pretty sure I can't be the first guy to ask this question.
I really like the Aqua-Computer Aquagrafix cooler for my 6800GT. I only have two questions on modability, and one on design.
1) I need 1/2" barbed fittings. Are those 'elbow adapters' at the page bottom barbed? Are they for this cooler?
2) I need the inlet/outlet ports facing different directions. I have a K8N Neo2 Platinum, and my water loop goes GPU-CPU-NB, so I'd need the inlet to be facing down (Like the two ports are in the picture), while the outlet faces the opposite direction, up toward the CPU. Can this be done? Do those elbow fittings screw in so I can just adjust to my heart's content?
3) There seems to be a small attached part that would cool the voltage regulators (by the power plug) on this cooler. Am I correct?
Thanks!
Thanks!
