I'm pretty new to raid. I do have a rather large amount of data to backup though. I'm around 12tb now. I had been using a bunch of external hard drives and mirroring them but that is stupid expensive and tedious now with these many drives. I was looking into a hardware raid solution but didn't like the fact that the drives are spinning all the time creating heat and using energy when they won't be used 99% of the time. I also didn't like the high cost of the raid cards plus expanders necessary for a large amount of drives. I will start with 10 drives in raid. Beyond that I'll need to have another case for direct attached storage. I started seeing references to snapshot raid and many mentions of flex raid. I really like that I can run it on windows since I don't plan to build a separate server for this. Just want to run 10 of the 12 drives I am putting into my new build in raid. Also already have much data on these drives so I was hoping to be able to preserve it.
What programs are out there that are relatively proven for snapshot raid? What is the general consensus here for using flexraid?
Will I be able to use this supermicro sata controller I currently have for flexraid or other snapshot raid? I already have this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815121009&cm_re=supermicro_controller-_-15-121-009-_-Product
Then will I be able to use this supermicro sas controller to connect to a separate direct attached storage? Other recommendations?
http://www.newegg.com/Product/Product.aspx?Item=N82E16816101358&cm_re=supermicro_controller-_-16-101-358-_-Product
