When I try to take a snapshot of a VM that is running ESXi 4.1 I get an error saying that
Error: File <unspecified filename> is larger than the maximum size supported by datastore '<unspecified datastore>
After doing some research VMware states this is an error that you get if your VMDK files are larger than the size that's supported by the block size of the datastore. Now the VM in question is provisioned with 2 256 GB drives. But looking at the datastore of the VM, the size of the VMDK's are over 268 GB. Question I have is how is the VMDK which is provisioned for 256 GB 12 GB's greater than that?
I'll be upgrading them to ESXi 5 very soon so this problem will goaway but was just curious.
